Various types of RAPID symbols
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntax[FlagsAttribute]
public enum SymbolTypes
Members|
| Member name | Value | Description |
| NoSymbol | 0 |
No symbol
| Constant | 16 |
Constant Rapid data instance
| Variable | 32 |
Variable Rapid data instance
| Persistent | 64 |
Persistent Rapid data instance
| Function | 1024 |
Rapid function routine
| Procedure | 2048 |
Rapid procedure routine
| Trap | 4096 |
Rapid trap routine
| Module | 8192 |
Rapid module
| Task | 16384 |
Rapid task
| Routine | 7168 |
Rapid routine (Function | Procedure | Trap)
| RapidData | 112 |
Rapid data instance (Constant | Variable | Persistent)
See Also
