ProgramPointer Class |
public class ProgramPointer
The ProgramPointer type exposes the following members.
| Name | Description | |
| End |
The end location of the pointer.
| Module |
The module in which the pointer is located.
| Routine |
The routine in which the pointer is located.
| Start |
The start location of the pointer.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
