SpeedData Structure |
public struct SpeedData : IRapidData
The SpeedData type exposes the following members.
| Name | Description | |
| vLeax |
The velocity of linear external axes in mm/s.
| vOri |
The velocity of reorientation about the TCP expressed in degrees/s.
| vReax |
The velocity of rotating external axes in degrees/s.
| vTcp |
The velocity of the tool center point (TCP).
| Equals | Indicates whether this instance and a specified object are equal. (Inherited from ValueType.) | |
| FillFromString |
Fills the struct with a valid rapid string representation.
| GetHashCode | Returns the hash code for this instance. (Inherited from ValueType.) | |
| ToString |
Returns the string representation of the speeddata rapid data.
(Overrides ValueTypeToString.) |
