JointTarget Structure |
public struct JointTarget : IRapidData
The JointTarget type exposes the following members.
| Name | Description | |
| Equals |
Determines whether the specified Object is equal to the current Object.
(Overrides ValueTypeEquals(Object).) | |
| FillFromString |
Fills the struct with a valid rapid string representation.
| GetHashCode |
Returns the hash code for this instance.
(Overrides ValueTypeGetHashCode.) | |
| ToString |
Returns the string representation of the jointtarget rapid data.
(Overrides ValueTypeToString.) |
| Equality |
== operator. Compares if two JointTarget are equal to each other.
| Inequality |
!= operator. Compares if two JointTarget differs from each other.
| Empty | Represents an undefined (empty) JointTarget.
The value of all fields are set to default, i.e. 0. | |
| ExtAx | Gets or sets the value of ExtAx. | |
| RobAx | Gets or sets the value of RobAx. | |
| Undefined | Represents an undefined JointTarget.
The value of all fields are set to NegativeInfinity. |
