Click or drag to resize
JointTargetEquals Method
Determines whether the specified Object is equal to the current Object.
Namespace:  ABB.Robotics.Controllers.RapidDomain
Assembly:  ABB.Robotics (in ABB.Robotics.dll) Version: 6.5.129.0
Syntax
C#
public override bool Equals(
	Object obj
Parameters
obj
Type: SystemObject
The Object to compare with the current Object.
Return Value
Type: Boolean
true if the specified Object is equal to the current Object; otherwise, false.
Exceptions
ExceptionCondition
NullReferenceExceptionThe obj parameter is null.
See Also
