RegainMode Enumeration |
public enum RegainMode
| Member name | Value | Description | |
| Continue | 0 | Brings the mechanical unit back to path only if the unit is within the configurable maximum distance from the path | |
| Regain | 1 | Moves the mechanical unit back to path. | |
| Clear | 2 | Clears the current path and continues the movement directly to the next target. |
