ModuleAttributes Enumeration |
Specifies possible module attributes. A module can have multiple attributes.
Namespace:
ABB.Robotics.Controllers.RapidDomain
Assembly:
Syntax[FlagsAttribute]
public enum ModuleAttributes
Members|
| Member name | Value | Description |
| None | 0 |
No attribute is specified
| SystemModule | 1 |
The module is a system module.
| Encoded | 2 |
The module is encoded, i.e. cannot be read without decryption.
| NoView | 4 |
The module cannot be viewed through the FlexPendant.
| NoStepIn | 8 |
The module cannot be step into, i.e. a routine will be executed as
one step independent of the number of instructions it contains.
| ViewOnly | 16 |
The module can only be viewed but not changed.
| ReadOnly | 32 |
See Also
