RapidData Class |
public sealed class RapidData : RapidSymbol, IDisposable
The RapidData type exposes the following members.
| Name | Description | |
| BaseIndex |
Sets or gets the base index of the data.
| ControllerType |
Gets the ControllerType.
(Inherited from SDKBase.) | |
| DataType |
Gets the RapidDataType of the Rapid data instance.
| DeclarationRange |
Returns information where this Rapid data instance is declared within its module.
| IsArray | Gets a value indicating whether the rapid data is an array. | |
| IsBuiltIn | Gets a value indicating whether the rapid data is built in or not. | |
| IsLocal |
Checks if the RAPID data is declared locally.
| IsTaskPers |
Checks if the RAPID data is declared PERS or TASKPERS. Only of interest for persistent data.
| ModuleName | Gets the name of the module where the rapid data is declared. | |
| Name |
Gets the name of the RapidSymbol.
(Inherited from RapidSymbol.) | |
| RapidType |
Gets the name of the RAPID data type.
| RoutineName | Gets the name of the routine in which the rapid data is declared. | |
| Scope |
Gets the scope of the RapidSymbol, i.e. TASK,MODULE,ROUTINE,...
| TaskName | Gets the name of the task in which the rapid data is declared. | |
| Type |
Get the type of the RapidSymbol.
| TypeUrl |
Gets the URL to the type symbol.
| Value |
Gets or sets the value of the RapidData.
| Dispose |
Disposes the managed resources of the instance.
(Inherited from SDKDisposeBase.) | |
| ReadItem |
Reads an item of the Rapid data array
| SearchRapidSymbol | General RapidSymbol search method. (Overrides RapidSymbolSearchRapidSymbol(RapidSymbolSearchProperties, String, String).) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) | |
| WriteItem |
Writes an item of the Rapid data array
| ValueChanged |
This event occurs when the value of the RapidData
has changed. It's only possible to get events from Rapid data
declared persistent.
