Controller Class |
Namespace: ABB.Robotics.Controllers
public sealed class Controller : SDKBase, IDisposable
The Controller type exposes the following members.
| Name | Description | |
| Controller |
Initializes a new instance of the Controller class, which is used to access the different domains of the controller.
| Controller(String) |
Initializes a new instance of the Controller class connected to a specific Robot Controller.
| AuthorizationSystem |
Gets the AuthorizationSystem
| BackupInProgress | Checks if the controller is busy finishing a backup. | |
| Configuration | Gets the ConfigurationDatabase class of the controller | |
| ControllerType |
Gets the ControllerType.
(Inherited from SDKBase.) | |
| CurrentUser |
Returns the name of the current user, eg. "Default User".
| DateTime |
Gets or sets current date and time in the controller.
| EventLog | Gets the EventLog class of the controller. | |
| FileSystem | Gets the FileSystem class of the controller. | |
| GateWay | Returns the Gateway address of the robot controller. | |
| IOSystem | Gets the IOSystem class of the controller | |
| IpAddress | Returns the IP address of the robot controller. | |
| IsVirtual |
Returns true if the controller is a virtual controller.
| MacAddress |
Returns the mac address of the controller.
| MotionSystem | Gets the MotionSystem class of the controller | |
| Name |
Returns the name of the robot controller.
| OperatingMode |
Gets the controller operating mode.
| Rapid | Gets the Rapid class of the controller | |
| RobotWareVersionName |
RobotWare Version Name
| State |
Gets the state of the controller.
| SubnetMask | Returns the Subnet mask address of the robot controller. |
| Backup |
This method starts a backup of the current robot system.
| Dispose |
Disposes the managed resources of the instance.
(Inherited from SDKDisposeBase.) | |
| GetCurrentMaster |
Gets the mastership status of a robot controller resource that is managed by means of mastership control.
| IsMaster |
Specifies whether we have mastership of a specific mastership resource.
| Restart |
Warmstart the controller
| Restart(RestartMode) |
Restart the controller
| Restore |
This method starts restoring a backup.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
| BackupFinished |
This event is generated when a backup is done.
| MastershipChanged |
Occurs when MasterShip has changed.
| OperatingModeChanged |
Occurs when the value of the controller OperatingMode has changed.
| StateChanged |
Occurs when the value of the controller State has changed.
private Controller myControllerRef = null; public TpsViewRefDoc() { // // Required for Windows Form Designer support // InitializeComponent(); // Create Controller instance, that can be used all over my // application myControllerRef = new Controller(); // Init rapid data, provide reference to Controller this.InitRapidData(myControllerRef); }
