This method starts a backup of the current robot system.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic void Backup(
string backupDir
Parameters
- backupDir
- Type: SystemString
Path to backup directory
Exceptions
Examples
This example takes a backup and stores it on the robot controller.
In this example a controller object 'c' has already been created. The event is a
button clicked event. The naming of the backup is just an example, you can
create your own standard.
private string _formatInteger(int number)
string answer = string.Empty;
if (number >= 10)
answer = integer.ToString();
else
answer = "0" + integer.ToString();
return answer;
private void c_BackupFinished(object sender, ABB.Robotics.Controllers.BackupEventArgs mode)
c.BackupFinished -= new ABB.Robotics.Controllers.BackupEventHandler(c_BackupFinished);
if (mode.Succeeded)
else
private void backup_Click(object sender, System.EventArgs e)
try
c.BackupFinished +=new ABB.Robotics.Controllers.BackupEventHandler(c_BackupFinished);
FileSystem f = c.FileSystem;
f.RemoteDirectory = "(TEMP$)";
string nameOfDir = "Backup_" + _formatInteger(c.Time.Year) + _formatInteger(c.Time.Month) +
_formatInteger(c.Time.Day);
c.Backup(f.RemoteDirectory+nameOfDir);
catch (System.Exception ee)
c.BackupFinished -=new ABB.Robotics.Controllers.BackupEventHandler(c_BackupFinished);
See Also
