ABB.Robotics.Controllers Namespace |
| Class | Description | |
| BackupEventArgs |
Defines an event structure for the BackupEventHandler which is the result of the
BackupFinished event.
| Controller |
This class represents a Robot controller. This class has to be created prior of any access to the robot controller.
| ControllerEventArgs |
Base class for the controller event arguments
| DeviceDriverStream |
This stream encapsulates the interface between a user mode application
and a device driver on the controller.
| MasterShip |
Defines mastership status of a robot controller resource
| MastershipChangedEventArgs |
Provides data for MastershipChanged event.
| OperatingModeChangedEventArgs |
Provides data for OperatingModeChanged event.
| SDKBase |
Summary description for SDKBase.
| SDKDisposeBase |
Base of all SDK classes that are Disposable
| StateChangedEventArgs |
Provides data for StateChanged event.
| UserAuthorizationSystem |
This class abstracts the UAS system of the controller
into the CAPI programming model.
| Structure | Description | |
| Grant |
Abstracts a controller grant.
| Delegate | Description | |
| BackupEventHandler |
Delegate for the BackupFinished event.
| MastershipChangedEventHandler |
Event handler for the MastershipChanged event.
| OperatingModeChangedEventHandler |
Event handler for the OperatingModeChanged event.
| StateChangedEventHandler |
Event handler for the StateChanged event.
| Enumeration | Description | |
| ControllerOperatingMode |
Specifies the operating modes of the controller.
| ControllerState |
Specifies the states of the controller.
| DeviceAccess |
This enum controls how a stream to the controller is opened.
| MastershipResource |
Resources available in the robot controller.
| MastershipStatus |
Defines mastership status.
| RestartMode |
Specifies how the controller is restarted.
| RestoreIgnore |
Represents if any mismatch can be ignored when a backup is restored.
| RestoreInclude |
Represents what to include when a backup is restored.
