ControllerMastershipChanged Event |
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntax
Exceptions
RemarksAny subscriber that wants to update their UI as a response to
the event has to redirect the execution to the UI-thread, using the
Invoke method.
Note: You should not switch to the UI-thread if you do not need to update the UI, as
a thread switch has an impact on performance.
Examples This example creates a
Controller instance and
sets up a subscription to the
MastershipChanged event. The event handler redirects
execution to another event handler, executing on the UI-thread (see Invoke method on TpsControl).
The latter retrieves further information about the current master.
bool ITpsViewSetup.Install(object sender,object data)
bool result = true;
try
c = new Controller();
c.MastershipChanged +=
new MastershipChangedEventHandler(c_MastershipChanged);
catch (System.Exception ee)
result = false;
return result;
private void c_MastershipChanged(object sender, MastershipChangedEventArgs e)
this.Invoke(new EventHandler(UpdateListbox),sender,e);
private void UpdateListbox(object sender, System.EventArgs e)
MastershipChangedEventArgs args = e as MastershipChangedEventArgs;
if (args != null)
if (args.Status == MastershipStatus.Remote)
Mastership ms = c.GetCurrentMaster(args.Resource);
See Also
