Gets the state of the controller.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntax
Exceptions
RemarksA call to the controller is performed each time this property is called. Thus, if you want to repeatedly check the
ControllerState in a conditional clause, you should get the controller state and save the value locally. See code example below.
ExamplesThis example gets the controller state and displays an associated text.
ControllerState state = c.State;
switch (state)
case ControllerState.EmergencyStop:
label4.Text = "Controller is in emergency stop state";
break;
case ControllerState.EmergencyStopReset:
label4.Text = "Controller is in emergency stop reset state";
break;
case ControllerState.GuardStop:
label4.Text = "Controller is in guard stop state";
break;
case ControllerState.Init:
label4.Text = "Controller is in initial state";
break;
case ControllerState.MotorsOff:
label4.Text = "Controller is in motors off state";
break;
case ControllerState.MotorsOn:
label4.Text = "Controller is in motors on state";
break;
case ControllerState.SystemFailure:
label4.Text = "Controller is in system failure state";
break;
case ControllerState.Unknown:
label4.Text = "Controller is in unknown state";
break;
See Also
