FileSystem Class |
Namespace: ABB.Robotics.Controllers.FileSystemDomain
public sealed class FileSystem : SDKBase, IDisposable
The FileSystem type exposes the following members.
| Name | Description | |
| ControllerType |
Gets the ControllerType.
(Inherited from SDKBase.) | |
| LocalDirectory | Gets or sets the directory of the local file system (FlexPendant). | |
| RemoteDirectory | Gets or sets the directory on the Robot Controller. | |
| StorageDevices |
Gets the storage devices known by the robot controller.
| CreateDirectory |
Creates a directory on the Robot Controller.
| Dispose |
Dispose the managed resources of the instance.
(Overrides SDKDisposeBaseDispose.) | |
| Exists |
Checks whether a file exists in the controller file system or not.
| GetEnvironmentVariableValue |
Returns the value of a specified environment variable.
| GetFile |
Gets a file from the Robot Controller and stores it on the local system.
| GetFilesAndDirectories |
Returns the files and directories of the Robot Controller that match the specified search pattern.
| PutFile |
Stores a file from the local system to the Robot Controller.
| RemoveDirectory |
Removes the specified directory from the Robot Controller.
| RemoveFile |
Deletes the specified file from the Robot Controller.
| RenameFile |
Renames the specified file on the Robot Controller.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
