Checks whether a file exists in the controller file system or not.
Namespace:
ABB.Robotics.Controllers.FileSystemDomain
Assembly:
Syntaxpublic bool Exists(
string path
Parameters
- path
- Type: SystemString
The full path of the file.
Return Value
Type:
BooleanTRUE if the files exists, otherwise FALSE.
RemarksIf the full path is given the specified path will be searched; otherwise the current directory will be searched.
Examples
This example checks if a specified file exists in the current directory of the controller.
Controller c = new Controller();
FileSystem fs = c.FileSystem;
string path = fs.RemoteDirectory + "\" + "test.mod";
if(fs.Exists(path))
else
fs.Dispose();
c.Dispose();
See Also
