MotionSystem Class |
Namespace: ABB.Robotics.Controllers.MotionDomain
public sealed class MotionSystem : SDKBase
The MotionSystem type exposes the following members.
| Name | Description | |
| ActiveMechanicalUnit |
Gets or sets the active mechanical unit name.
| ControllerType |
Gets the ControllerType.
(Inherited from SDKBase.) | |
| IncrementalMode |
Gets or sets the incremental jogging mode.
| Dispose |
Disposes the managed resources of the instance.
(Overrides SDKDisposeBaseDispose.) | |
| GetActiveMechanicalUnit |
Gets the active mechanical unit.
| GetMechanicalUnits |
Gets all mechanical units defined in the robot controller.
| JoggingStart |
Sends a start jogging request to the robot controller.
| JoggingStop |
Sends a stop jogging request to the robot controller.
| SetJoggingCmd |
Sets the jogging command that will be executed when the jogging starts with JoggingStart.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
| ActiveMechanicalUnitChanged |
This event is raised at a change of the active mechanical unit.
| IncrementalModeChanged |
This event is raised when the incremental mode is changed.
Controller c = new Controller();
MotionSystem motion = c.MotionSystem;
