MechanicalUnit Class |
Namespace: ABB.Robotics.Controllers.MotionDomain
public sealed class MechanicalUnit : SDKBase, IDisposable
The MechanicalUnit type exposes the following members.
| Name | Description | |
| ControllerType |
Gets the ControllerType.
(Inherited from SDKBase.) | |
| CoordinateSystem |
Gets or sets the coordinate system mode for jogging of the active mechanical unit.
| IsCalibrated |
Specifies whether the mechanical unit is calibrated or not.
| MotionMode |
Gets or sets the motion mode type for jogging of the robot.
| Name |
Gets the name of the mechanical unit.
| NoOfAxes | Gets the number of axes of the mechanical unit. | |
| Task |
Returns the name of the task of the mechanical unit.
| Tool |
Gets or sets the active tool.
| Type | Gets the mechanical unit type. | |
| WorkObjectName |
Gets or sets the active work object.
| Dispose |
Disposes the managed resources of the instance.
(Inherited from SDKDisposeBase.) | |
| GetPosition |
Gets the joint target position of the mechanical unit.
| GetPosition(CoordinateSystemType) |
Gets the robtarget position of the mechanical unit.
| GetPosition2 |
| GetUserDefIncStepSize |
Gets the user defined incremental step size.
| SetUserDefIncStepSize |
Sets the user defined incremental step size.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
| DataChanged |
This event is raised at any change of the mechanical unit data, e.g. tool changed,
work object changed, coordinated system changed, motion mode changed or incremental step size changed.
The event handler receives an event of the type MechanicalUnitDataEventArgs.
