MechanicalUnitGetUserDefIncStepSize Method |
Gets the user defined incremental step size.
Namespace:
ABB.Robotics.Controllers.MotionDomain
Assembly:
Syntax
Exceptions
RemarksOnly supported by mechanical unit type TCPRobot.
ExamplesThis example gets the incremental step size for joint wise movement of the active mechanical unit.
Controller c = new Controller();
MotionSystem motion = c.MotionSystem;
MechanicalUnit mech = motion.GetActiveMechanicalUnit();
float val = mech.GetUserDefIncStepSize(UserDefIncStepSizeMode.Joint);
See Also
