MechanicalUnitGetPosition2 Method |
Gets the joint target position of the mechanical unit.
Namespace:
ABB.Robotics.Controllers.MotionDomain
Assembly:
Syntaxpublic JointTarget GetPosition2()
Return Value
Type:
JointTargetThe position of the mechanical unit as a
JointTarget.
ExamplesThis example gets the current joint target position of the active mechanical unit and It will map the value according to axis position.
Controller c = new Controller();
MotionSystem motion = c.MotionSystem;
MechanicalUnit mech = motion.GetActiveMechanicalUnit();
JointTarget robTgt;
robTgt = mech.GetPosition2();
See Also
