MechanicalUnit Events |
The MechanicalUnit type exposes the following members.
| Name | Description | |
| DataChanged |
This event is raised at any change of the mechanical unit data, e.g. tool changed,
work object changed, coordinated system changed, motion mode changed or incremental step size changed.
The event handler receives an event of the type MechanicalUnitDataEventArgs.
