Defines the different plot symbols
Namespace:
Assembly:
Syntax
Members|
| Member name | Value | Description |
| Circle | 0 |
A circle will be drawn at the data point
| Square | 1 |
A square will be drawn at the data point
| Diamond | 2 |
A diamond will be drawn at the data point
| Triangle | 3 |
A triangle will be drawn at the data point
| InvertedTriangle | 4 |
An inverted triangle will be drawn at the data point
| Custom | 5 |
A custom symbol provided by the Symbol Bitmap will be drawn at the data point
See Also
