TextBoxWrapper Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class TextBoxWrapper
The TextBoxWrapper type exposes the following members.
| Name | Description | |
| TextBoxWrapper |
Initializes a new instance of the TextBoxWrapper class.
| MaxLength |
Maximum length for the text box
| SelectionLength |
Selection length for text box
| SelectionStart |
Slelection start for textbox
| TextBox | Gets or sets the TextBoxBase target. | |
| TextLength |
| Delete |
This deletes the text. It simulates the BackSpace function.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| Focus |
Set textbox in focus status
| MoveCaret |
Move the caret to the left or to the right
| Select |
Select text of specified area
| SelectAll |
Select all the text
| SendChar |
Inserts an string into the textbox at the SelectionStart value.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
