TextBoxWrapper Methods |
The TextBoxWrapper type exposes the following members.
| Name | Description | |
| Delete |
This deletes the text. It simulates the BackSpace function.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| Focus |
Set textbox in focus status
| MoveCaret |
Move the caret to the left or to the right
| Select |
Select text of specified area
| SelectAll |
Select all the text
| SendChar |
Inserts an string into the textbox at the SelectionStart value.
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
