Grid Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class Grid : ViComponent
The Grid type exposes the following members.
| Name | Description | |
| Grid |
Initializes a new instance of the Grid class.
| Grid(Boolean, Boolean, Color, Int32) |
Initializes a new instance of the Grid class with specific data.
| Color |
The color of the grid
| HorizontalVisible |
Determines whether the horizontal grid is visible or hidden
| LineThickness |
The thickness of the grid line
| VerticalVisible |
Determines whether the vertical grid is visible or hidden
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| ToString |
Overridden. Returns visible grids.
(Overrides ObjectToString.) |
