Click or drag to resize
CommandBar Class
Represents a component to add menues and commands to your FlexPendant view. A CommandBar is used to host a MainMenu instance. With a MainMenu you can add menues and commands to your view.
Inheritance Hierarchy
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public class CommandBar : TpsControl
The CommandBar type exposes the following members.
Constructors
  NameDescription
Public methodCommandBar
Initializes a new instance of the CommandBar class.
Top
Properties
  NameDescription
Public propertyAccessibilityObject
Gets the AccessibleObject assigned to the control.
(Inherited from Control.)
Public propertyAccessibleDefaultActionDescription
Gets or sets the default action description of the control for use by accessibility client applications.
Public propertyAccessibleDescription
Gets or sets the description of the control used by accessibility client applications.
Public propertyAccessibleName
Gets or sets the name of the control used by accessibility client applications.
Public propertyAccessibleRole
Gets or sets the accessible role of the control
Public propertyActiveControl
Gets or sets the active control on the container control.
(Inherited from ContainerControl.)
Public propertyAllowDrop
Gets or sets a value indicating whether the control can accept data that the user drags onto it.
Public propertyAnchor
Gets or sets the edges of the container to which a control is bound and determines how a control is resized with its parent.
Public propertyAutoScaleDimensions
Gets or sets the dimensions that the control was designed to.
Protected propertyAutoScaleFactor
Gets the scaling factor between the current and design-time automatic scaling dimensions.
Public propertyAutoScaleMode
Gets or sets the automatic scaling mode of the control.
Public propertyAutoScroll
Gets or sets a value indicating whether the container enables the user to scroll to any controls placed outside of its visible boundaries.
(Inherited from ScrollableControl.)
Public propertyAutoScrollMargin
Gets or sets the size of the auto-scroll margin.
Public propertyAutoScrollMinSize
Gets or sets the minimum size of the auto-scroll.
Public propertyAutoScrollOffset
Gets or sets where this control is scrolled to in ScrollControlIntoView(Control).
Public propertyAutoScrollPosition
Gets or sets the location of the auto-scroll position.
Public propertyAutoSize (Inherited from UserControl.)
Public propertyAutoSizeMode
Gets or sets how the control will resize itself.
Public propertyAutoValidate
Gets or sets how the control performs validation when the user changes focus to another control.
Public propertyBackColor
Gets or sets the background color for the control.
Public propertyBackgroundImage
Gets or sets the background image displayed in the control.
Public propertyBackgroundImageLayout
Gets or sets the background image layout as defined in the ImageLayout enumeration.
Public propertyBindingContext (Inherited from ContainerControl.)
Public propertyBorderStyle
Gets or sets the border style of the user control.
Public propertyBottom
Gets the distance, in pixels, between the bottom edge of the control and the top edge of its container's client area.
Public propertyBounds
Gets or sets the size and location of the control including its nonclient elements, in pixels, relative to the parent control.
Protected propertyCanEnableIme
Gets a value indicating whether the ImeMode property can be set to an active value, to enable IME support.
Public propertyCanFocus
Gets a value indicating whether the control can receive focus.
Protected propertyCanRaiseEvents
Determines if events can be raised on the control.
Public propertyCanSelect
Gets a value indicating whether the control can be selected.
Public propertyCapture
Gets or sets a value indicating whether the control has captured the mouse.
Public propertyCausesValidation
Gets or sets a value indicating whether the control causes validation to be performed on any controls that require validation when it receives focus.
Public propertyClientRectangle
Gets the rectangle that represents the client area of the control.
Public propertyClientSize
Gets or sets the height and width of the client area of the control.
Public propertyCompanyName
Gets the name of the company or creator of the application containing the control.
Public propertyContainer
Gets the IContainer that contains the Component.
(Inherited from Component.)
Public propertyContainsFocus
Gets a value indicating whether the control, or one of its child controls, currently has the input focus.
Public propertyContextMenu
Gets or sets the shortcut menu associated with the control.
(Inherited from TpsControl.)
Public propertyContextMenuStrip
Gets or sets the ContextMenuStrip associated with this control.
Public propertyControls
Gets the collection of controls contained within the control.
Public propertyCreated
Gets a value indicating whether the control has been created.
Protected propertyCreateParams (Inherited from UserControl.)
Public propertyCurrentAutoScaleDimensions
Gets the current run-time dimensions of the screen.
Public propertyCursor
Gets or sets the cursor that is displayed when the mouse pointer is over the control.
Public propertyDataBindings
Gets the data bindings for the control.
Protected propertyDefaultCursor
Gets or sets the default cursor for the control.
Protected propertyDefaultImeMode
Gets the default Input Method Editor (IME) mode supported by the control.
Protected propertyDefaultMargin
Gets the space, in pixels, that is specified by default between controls.
Protected propertyDefaultMaximumSize
Gets the length and height, in pixels, that is specified as the default maximum size of a control.
Protected propertyDefaultMinimumSize
Gets the length and height, in pixels, that is specified as the default minimum size of a control.
Protected propertyDefaultPadding
Gets the internal spacing, in pixels, of the contents of a control.
Protected propertyDefaultSize (Inherited from UserControl.)
Protected propertyDesignMode
Gets a value that indicates whether the Component is currently in design mode.
Protected propertyDisabledForeColor
Gets or sets the value of the forecolor used when the control is disabled. Some controls do not change its visual appearance when disabled. This property has no effect for those controls.
Public propertyDisplayRectangle
Gets the rectangle that represents the virtual display area of the control.
Public propertyDisposing
Gets a value indicating whether the base Control class is in the process of disposing.
Public propertyDock
Gets or sets which control borders are docked to its parent control and determines how a control is resized with its parent.
Public propertyDockPadding
Gets the dock padding settings for all edges of the control.
Protected propertyDoubleBuffered
Gets or sets a value indicating whether this control should redraw its surface using a secondary buffer to reduce or prevent flicker.
Public propertyEnabled
Gets or sets a value indicating whether the control can respond to user interaction.
Protected propertyEvents
Gets the list of event handlers that are attached to this Component.
Public propertyFocused
Gets a value indicating whether the control has input focus.
Public propertyFont
Gets or sets the font of the text displayed by the control.
Protected propertyFontHeight
Gets or sets the height of the font of the control.
Public propertyFontName Obsolete.
The font that should be used for the TpsControl. The Control Font property is hidden from the property grid so that the user shouldn't be able to select Fonts which are not compatible with the FlexPendant.
Public propertyForeColor
Gets or sets the foreground color of the control.
Public propertyHandle
Gets the window handle that the control is bound to.
Public propertyHasChildren
Gets a value indicating whether the control contains one or more child controls.
Public propertyHeight
Gets or sets the height of the control.
Public propertyHorizontalScroll
Gets the characteristics associated with the horizontal scroll bar.
Protected propertyHScroll
Gets or sets a value indicating whether the horizontal scroll bar is visible.
Public propertyImeMode
Gets or sets the Input Method Editor (IME) mode of the control.
Protected propertyImeModeBase
Gets or sets the IME mode of a control.
Public propertyInvokeRequired
Gets a value indicating whether the caller must call an invoke method when making method calls to the control because the caller is on a different thread than the one the control was created on.
Public propertyIsAccessible
Gets or sets a value indicating whether the control is visible to accessibility applications.
Protected propertyCode exampleIsDisposed
Gets or sets a value indicating whether the object has already been disposed or not.
Public propertyIsEventEnabled
Gets or sets the status if events shall be processed by the control. This a property controlled by the derived class but the default behaviour is true in the constructor and false in the Dispose method.
Public propertyIsHandleCreated
Gets a value indicating whether the control has a handle associated with it.
Public propertyIsMirrored
Gets a value indicating whether the control is mirrored.
Public propertyLayoutEngine
Gets a cached instance of the control's layout engine.
Public propertyLeft
Gets or sets the distance, in pixels, between the left edge of the control and the left edge of its container's client area.
Public propertyLocation
Gets or sets the coordinates of the upper-left corner of the control relative to the upper-left corner of its container.
Public propertyMargin
Gets or sets the space between controls.
Public propertyMaximumSize
Gets or sets the size that is the upper limit that GetPreferredSize(Size) can specify.
Public propertyMenu
Gets or sets the MainMenu that is host by the CommandBar.
Public propertyMenuItems
Gets the menu itmes in commandbar
Public propertyMinimumSize
Gets or sets the size that is the lower limit that GetPreferredSize(Size) can specify.
Public propertyName
Gets or sets the name of the control.
Public propertyPadding
Gets or sets padding within the control.
Public propertyParent
Gets or sets the parent container of the control.
Public propertyParentForm
Gets the form that the container control is assigned to.
Public propertyPreferredSize
Gets the size of a rectangular area into which the control can fit.
Public propertyProductName
Gets the product name of the assembly containing the control.
Public propertyProductVersion
Gets the version of the assembly containing the control.
Public propertyRecreatingHandle
Gets a value indicating whether the control is currently re-creating its handle.
Public propertyRegion
Gets or sets the window region associated with the control.
Protected propertyRenderRightToLeft Obsolete.
This property is now obsolete.
Protected propertyResizeRedraw
Gets or sets a value indicating whether the control redraws itself when resized.
Public propertyRight
Gets the distance, in pixels, between the right edge of the control and the left edge of its container's client area.
Public propertyRightToLeft
Gets or sets a value indicating whether control's elements are aligned to support locales using right-to-left fonts.
Protected propertyScaleChildren
Gets a value that determines the scaling of child controls.
Public propertySelectionColor
Gets or sets the color when an item is selected. Default color is RGB(0,172,182)
Protected propertyShowFocusCues
Gets a value indicating whether the control should display focus rectangles.
Protected propertyShowKeyboardCues
Gets a value indicating whether the user interface is in the appropriate state to show or hide keyboard accelerators.
Public propertySite
Gets or sets the site of the control.
Public propertySize
Gets or sets the height and width of the control.
Public propertyTabIndex
Gets or sets the tab order of the control within its container.
Public propertyTabStop
Gets or sets a value indicating whether the user can give the focus to this control using the TAB key.
Public propertyTag
Gets or sets the object that contains data about the control.
Public propertyText (Inherited from UserControl.)
Public propertyTop
Gets or sets the distance, in pixels, between the top edge of the control and the top edge of its container's client area.
Public propertyTopLevelControl
Gets the parent control that is not parented by another Windows Forms control. Typically, this is the outermost Form that the control is contained in.
Public propertyUseWaitCursor
Gets or sets a value indicating whether to use the wait cursor for the current control and all child controls.
Public propertyVerticalScroll
Gets the characteristics associated with the vertical scroll bar.
Public propertyVisible
Gets or sets a value indicating whether the control and all its child controls are displayed.
Protected propertyVScroll
Gets or sets a value indicating whether the vertical scroll bar is visible.
Public propertyWidth
Gets or sets the width of the control.
Public propertyWindowTarget
This property is not relevant for this class.
Top
Methods
  NameDescription
Protected methodAccessibilityNotifyClients(AccessibleEvents, Int32)
Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control.
Protected methodAccessibilityNotifyClients(AccessibleEvents, Int32, Int32)
Notifies the accessibility client applications of the specified AccessibleEvents for the specified child control .
Protected methodAdjustFormScrollbars (Inherited from ContainerControl.)
Public methodBeginInvoke(Delegate)
Executes the specified delegate asynchronously on the thread that the control's underlying handle was created on.
Public methodBeginInvoke(EventHandler)
Public methodBeginInvoke(Delegate, Object)
Executes the specified delegate asynchronously with the specified arguments, on the thread that the control's underlying handle was created on.
Public methodBeginInvoke(EventHandler, Object)
Public methodBeginInvokeEx Obsolete.
Executes the specified EventHandler asynchronously.
Public methodBringToFront
Brings the control to the front of the z-order.
Public methodContains
Retrieves a value indicating whether the specified control is a child of the control.
Protected methodCreateAccessibilityInstance
Creates a new accessibility object for the control.
Public methodCreateControl
Forces the creation of the visible control, including the creation of the handle and any visible child controls.
Protected methodCreateControlsInstance
Creates a new instance of the control collection for the control.
Public methodCreateGraphics
Creates the Graphics for the control.
Protected methodCreateHandle
Creates a handle for the control.
Public methodCreateObjRef
Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object.
(Inherited from MarshalByRefObject.)
Protected methodDefWndProc
Sends the specified message to the default window procedure.
Protected methodDestroyHandle
Destroys the handle associated with the control.
Public methodDispose
Releases all resources used by the Component.
Protected methodDispose(Boolean)
Releases all resources used by this CommandBar instance.
(Overrides TpsControlDispose(Boolean).)
Public methodDoDragDrop
Begins a drag-and-drop operation.
Public methodDrawToBitmap
Supports rendering to the specified bitmap.
Public methodEndInvoke
Retrieves the return value of the asynchronous operation represented by the IAsyncResult passed.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Destructor.
Public methodFindForm
Retrieves the form that the control is on.
Public methodFocus
Sets input focus to the control.
Protected methodGetAccessibilityObjectById
Retrieves the specified AccessibleObject.
Protected methodGetAutoSizeMode
Retrieves a value indicating how a control will behave when its AutoSize property is enabled.
Public methodGetChildAtPoint(Point)
Retrieves the child control that is located at the specified coordinates.
Public methodGetChildAtPoint(Point, GetChildAtPointSkip)
Retrieves the child control that is located at the specified coordinates, specifying whether to ignore child controls of a certain type.
Public methodGetContainerControl
Returns the next ContainerControl up the control's chain of parent controls.
Protected methodGetForeColor
Returns the ForeColor used when the control is enabled or disabled.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetLifetimeService
Retrieves the current lifetime service object that controls the lifetime policy for this instance.
Public methodGetNextControl
Retrieves the next control forward or back in the tab order of child controls.
Public methodGetPreferredSize
Retrieves the size of a rectangular area into which a control can be fitted.
Protected methodGetScaledBounds
Retrieves the bounds within which the control is scaled.
Protected methodGetScrollState
Determines whether the specified flag has been set.
Protected methodGetService
Returns an object that represents a service provided by the Component or by its Container.
Protected methodGetStyle
Retrieves the value of the specified control style bit for the control.
Protected methodGetTopLevel
Determines if the control is a top-level control.
Public methodGetType
Gets the type of the current instance.
Public methodHide
Conceals the control from the user.
Public methodInitializeLifetimeService
Obtains a lifetime service object to control the lifetime policy for this instance.
Protected methodInitLayout
Called after the control has been added to another container.
Public methodInvalidate
Invalidates the entire surface of the control and causes the control to be redrawn.
Public methodInvalidate(Region)
Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control.
Public methodInvalidate(Boolean)
Invalidates a specific region of the control and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control.
Public methodInvalidate(Rectangle)
Public methodInvalidate(Region, Boolean)
Invalidates the specified region of the control (adds it to the control's update region, which is the area that will be repainted at the next paint operation), and causes a paint message to be sent to the control. Optionally, invalidates the child controls assigned to the control.
Public methodInvalidate(Rectangle, Boolean)
Public methodInvoke(Delegate)
Executes the specified delegate on the thread that owns the control's underlying window handle.
Public methodInvoke(Delegate, Object)
Executes the specified delegate, on the thread that owns the control's underlying window handle, with the specified list of arguments.
Public methodInvoke(EventHandler, Object)
Protected methodInvokeGotFocus
Raises the GotFocus event for the specified control.
Protected methodInvokeLostFocus
Raises the LostFocus event for the specified control.
Protected methodInvokeOnClick
Raises the Click event for the specified control.
Protected methodInvokePaint
Raises the Paint event for the specified control.
Protected methodInvokePaintBackground
Raises the PaintBackground event for the specified control.
Protected methodIsInputChar
Determines if a character is an input character that the control recognizes.
Protected methodIsInputKey
Determines whether the specified key is a regular input key or a special key that requires preprocessing.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodMemberwiseClone(Boolean)
Creates a shallow copy of the current MarshalByRefObject object.
Protected methodNotifyInvalidate
Raises the Invalidated event with a specified region of the control to invalidate.
Protected methodOnAutoSizeChanged
Raises the AutoSizeChanged event.
Protected methodOnAutoValidateChanged
Raises the AutoValidateChanged event.
Protected methodOnBackColorChanged
Raises the BackColorChanged event.
Protected methodOnBackgroundImageChanged
Raises the BackgroundImageChanged event.
Protected methodOnBackgroundImageLayoutChanged (Inherited from Control.)
Protected methodOnBindingContextChanged
Raises the BindingContextChanged event.
Protected methodOnCausesValidationChanged
Raises the CausesValidationChanged event.
Protected methodOnChangeUICues
Raises the ChangeUICues event.
Protected methodOnClick
Raises the Click event.
Protected methodOnClientSizeChanged
Raises the ClientSizeChanged event.
Protected methodOnContextMenuChanged
Raises the ContextMenuChanged event.
Protected methodOnContextMenuStripChanged
Raises the ContextMenuStripChanged event.
Protected methodOnControlAdded
Raises the ControlAdded event.
Protected methodOnControlRemoved
Raises the ControlRemoved event.
Protected methodOnCreateControl
Raises the CreateControl event.
Protected methodOnCursorChanged
Raises the CursorChanged event.
Protected methodOnDockChanged
Raises the DockChanged event.
Protected methodOnDoubleClick
Raises the DoubleClick event.
Protected methodOnDragDrop
Raises the DragDrop event.
Protected methodOnDragEnter
Raises the DragEnter event.
Protected methodOnDragLeave
Raises the DragLeave event.
Protected methodOnDragOver
Raises the DragOver event.
Protected methodOnEnabledChanged
Raises the EnabledChanged event.
(Overrides ControlOnEnabledChanged(EventArgs).)
Protected methodOnEnter
Raises the Enter event.
Protected methodOnFontChanged
Raises the FontChanged event.
Protected methodOnForeColorChanged
Raises the ForeColorChanged event.
Protected methodOnGiveFeedback
Raises the GiveFeedback event.
Protected methodOnGotFocus
Raises the GotFocus event.
Protected methodOnHandleCreated
Raises the HandleCreated event.
Protected methodOnHandleDestroyed
Raises the HandleDestroyed event.
Protected methodOnHelpRequested
Raises the HelpRequested event.
Protected methodOnImeModeChanged
Raises the ImeModeChanged event.
Protected methodOnInvalidated
Raises the Invalidated event.
Protected methodOnKeyDown
Raises the KeyDown event.
Protected methodOnKeyPress
Raises the KeyPress event.
Protected methodOnKeyUp
Raises the KeyUp event.
Protected methodOnLayout (Inherited from ContainerControl.)
Protected methodOnLeave
Raises the Leave event.
Protected methodOnLoad
Raises the Load event.
Protected methodOnLocationChanged
Raises the LocationChanged event.
Protected methodOnLostFocus
Raises the LostFocus event.
Protected methodOnMarginChanged
Raises the MarginChanged event.
Protected methodOnMouseCaptureChanged
Raises the MouseCaptureChanged event.
Protected methodOnMouseClick
Raises the MouseClick event.
Protected methodOnMouseDoubleClick
Raises the MouseDoubleClick event.
Protected methodOnMouseDown
Raises the MouseDown event.
(Overrides UserControlOnMouseDown(MouseEventArgs).)
Protected methodOnMouseEnter
Raises the MouseEnter event.
Protected methodOnMouseHover
Raises the MouseHover event.
Protected methodOnMouseLeave
Raises the MouseLeave event.
Protected methodOnMouseMove
Raises the MouseMove event.
Protected methodOnMouseUp
Raises the MouseUp event.
(Overrides ControlOnMouseUp(MouseEventArgs).)
Protected methodOnMouseWheel
Raises the MouseWheel event.
Protected methodOnMove
Raises the Move event.
Protected methodOnNotifyMessage
Notifies the control of Windows messages.
Protected methodOnPaddingChanged
Raises the PaddingChanged event.
Protected methodOnPaint
Raises the Paint event.
(Overrides ControlOnPaint(PaintEventArgs).)
Protected methodOnPaintBackground
Prevents painting the background of the TpsCtrlLabelButton control.
(Overrides ScrollableControlOnPaintBackground(PaintEventArgs).)
Protected methodOnParentBackColorChanged
Raises the BackColorChanged event when the BackColor property value of the control's container changes.
Protected methodOnParentBackgroundImageChanged
Raises the BackgroundImageChanged event when the BackgroundImage property value of the control's container changes.
Protected methodOnParentBindingContextChanged
Raises the BindingContextChanged event when the BindingContext property value of the control's container changes.
Protected methodOnParentChanged (Inherited from ContainerControl.)
Protected methodOnParentCursorChanged
Protected methodOnParentEnabledChanged
Raises the EnabledChanged event when the Enabled property value of the control's container changes.
Protected methodOnParentFontChanged
Raises the FontChanged event when the Font property value of the control's container changes.
Protected methodOnParentForeColorChanged
Raises the ForeColorChanged event when the ForeColor property value of the control's container changes.
Protected methodOnParentRightToLeftChanged
Raises the RightToLeftChanged event when the RightToLeft property value of the control's container changes.
Protected methodOnParentVisibleChanged
Raises the VisibleChanged event when the Visible property value of the control's container changes.
Protected methodOnPreviewKeyDown
Raises the PreviewKeyDown event.
Protected methodOnPrint
Protected methodOnQueryContinueDrag
Raises the QueryContinueDrag event.
Protected methodOnRegionChanged
Raises the RegionChanged event.
Protected methodOnResize (Inherited from UserControl.)
Protected methodOnRightToLeftChanged (Inherited from ScrollableControl.)
Protected methodOnScroll
Raises the Scroll event.
Protected methodOnSizeChanged
Raises the SizeChanged event.
Protected methodOnStyleChanged
Raises the StyleChanged event.
Protected methodOnSystemColorsChanged
Raises the SystemColorsChanged event.
Protected methodOnTabIndexChanged
Raises the TabIndexChanged event.
Protected methodOnTabStopChanged
Raises the TabStopChanged event.
Protected methodOnTextChanged
Raises the TextChanged event.
Protected methodOnValidated
Raises the Validated event.
Protected methodOnValidating
Raises the Validating event.
Protected methodOnVisibleChanged (Inherited from ScrollableControl.)
Public methodPerformAutoScale
Performs scaling of the container control and its children.
Public methodPerformLayout
Forces the control to apply layout logic to all its child controls.
Public methodPerformLayout(Control, String)
Public methodPointToClient
Computes the location of the specified screen point into client coordinates.
Public methodPointToScreen
Computes the location of the specified client point into screen coordinates.
Public methodPreProcessControlMessage
Preprocesses keyboard or input messages within the message loop before they are dispatched.
Public methodPreProcessMessage
Protected methodProcessCmdKey (Inherited from ContainerControl.)
Protected methodProcessDialogChar (Inherited from ContainerControl.)
Protected methodProcessDialogKey (Inherited from ContainerControl.)
Protected methodProcessKeyEventArgs
Processes a key message and generates the appropriate control events.
Protected methodProcessKeyMessage
Processes a keyboard message.
Protected methodProcessKeyPreview
Previews a keyboard message.
Protected methodProcessMnemonic (Inherited from ContainerControl.)
Protected methodProcessTabKey
Selects the next available control and makes it the active control.
Protected methodRaiseDragEvent
Raises the appropriate drag event.
Protected methodRaiseKeyEvent
Raises the appropriate key event.
Protected methodRaiseMouseEvent
Raises the appropriate mouse event.
Protected methodRaisePaintEvent
Raises the appropriate paint event.
Protected methodRecreateHandle
Forces the re-creation of the handle for the control.
Public methodRectangleToClient
Computes the size and location of the specified screen rectangle in client coordinates.
Public methodRectangleToScreen
Computes the size and location of the specified client rectangle in screen coordinates.
Public methodRefresh
Forces the control to invalidate its client area and immediately redraw itself and any child controls.
Public methodResetBackColor
Resets the BackColor property to its default value.
Public methodResetBindings
Causes a control bound to the BindingSource to reread all the items in the list and refresh their displayed values.
Public methodResetCursor
Resets the Cursor property to its default value.
Public methodResetFont
Resets the Font property to its default value.
Public methodResetForeColor
Resets the ForeColor property to its default value.
Public methodResetImeMode
Resets the ImeMode property to its default value.
Protected methodResetMouseEventArgs
Resets the control to handle the MouseLeave event.
Public methodResetRightToLeft
Resets the RightToLeft property to its default value.
Public methodResetText
Resets the Text property to its default value.
Public methodResumeLayout
Resumes usual layout logic.
Public methodResumeLayout(Boolean)
Resumes usual layout logic, optionally forcing an immediate layout of pending layout requests.
Protected methodRtlTranslateAlignment(HorizontalAlignment)
Converts the specified HorizontalAlignment to the appropriate HorizontalAlignment to support right-to-left text.
Protected methodRtlTranslateAlignment(LeftRightAlignment)
Converts the specified LeftRightAlignment to the appropriate LeftRightAlignment to support right-to-left text.
Protected methodRtlTranslateAlignment(ContentAlignment)
Converts the specified ContentAlignment to the appropriate ContentAlignment to support right-to-left text.
Protected methodRtlTranslateContent
Protected methodRtlTranslateHorizontal
Protected methodRtlTranslateLeftRight
Public methodScale(Single) Obsolete.
Scales the control and any child controls.
Public methodScale(SizeF)
Scales the control and all child controls by the specified scaling factor.
Public methodScale(Single, Single) Obsolete.
Scales the entire control and any child controls.
Protected methodScaleControl (Inherited from ScrollableControl.)
Protected methodScaleCore (Inherited from ScrollableControl.)
Public methodScrollControlIntoView
Scrolls the specified child control into view on an auto-scroll enabled control.
Protected methodScrollToControl
Calculates the scroll offset to the specified child control.
Public methodSelect
Activates the control.
Protected methodSelect(Boolean, Boolean) (Inherited from ContainerControl.)
Public methodSelectNextControl
Activates the next control.
Public methodSendToBack
Sends the control to the back of the z-order.
Public methodSetAutoScrollMargin
Sets the size of the auto-scroll margins.
Protected methodSetAutoSizeMode
Sets a value indicating how a control will behave when its AutoSize property is enabled.
Public methodSetBounds(Int32, Int32, Int32, Int32)
Sets the bounds of the control to the specified location and size.
Public methodSetBounds(Int32, Int32, Int32, Int32, BoundsSpecified)
Sets the specified bounds of the control to the specified location and size.
Protected methodSetBoundsCore
Performs the work of setting the specified bounds of this control.
Protected methodSetClientSizeCore
Sets the size of the client area of the control.
Protected methodSetDisplayRectLocation
Positions the display window to the specified value.
Protected methodSetScrollState
Sets the specified scroll state flag.
Protected methodSetStyle
Sets a specified ControlStyles flag to either true or false.
Protected methodSetTopLevel
Sets the control as the top-level control.
Protected methodSetVisibleCore
Sets the control to the specified visible state.
Public methodShow
Displays the control to the user.
Protected methodSizeFromClientSize
Determines the size of the entire control from the height and width of its client area.
Public methodSuspendLayout
Temporarily suspends the layout logic for the control.
Public methodToString
Returns a String containing the name of the Component, if any. This method should not be overridden.
Public methodUpdate
Causes the control to redraw the invalidated regions within its client area.
Protected methodUpdateBounds
Updates the bounds of the control with the current size and location.
Protected methodUpdateBounds(Int32, Int32, Int32, Int32)
Updates the bounds of the control with the specified size and location.
Protected methodUpdateBounds(Int32, Int32, Int32, Int32, Int32, Int32)
Updates the bounds of the control with the specified size, location, and client size.
Protected methodUpdateDefaultButton
When overridden by a derived class, updates which button is the default button.
Protected methodUpdateStyles
Forces the assigned styles to be reapplied to the control.
Protected methodUpdateZOrder
Updates the control in its parent's z-order.
Public methodValidate
Verifies the value of the control losing focus by causing the Validating and Validated events to occur, in that order.
Public methodValidate(Boolean)
Verifies the value of the control that is losing focus; conditionally dependent on whether automatic validation is turned on.
Public methodValidateChildren (Inherited from UserControl.)
Public methodValidateChildren(ValidationConstraints) (Inherited from UserControl.)
Protected methodWndProc (Inherited from UserControl.)
Top
Events
  NameDescription
Public eventAutoSizeChanged
Occurs when the AutoSize property changes.
Public eventAutoValidateChanged
Occurs when the AutoValidate property changes.
Public eventBackColorChanged
Occurs when the value of the BackColor property changes.
Public eventBackgroundImageChanged
Occurs when the value of the BackgroundImage property changes.
Public eventBackgroundImageLayoutChanged
Occurs when the BackgroundImageLayout property changes.
Public eventBindingContextChanged
Occurs when the value of the BindingContext property changes.
Public eventCausesValidationChanged
Occurs when the value of the CausesValidation property changes.
Public eventChangeUICues
Occurs when the focus or keyboard user interface (UI) cues change.
Public eventClick
Occurs when the control is clicked.
Public eventClientSizeChanged
Occurs when the value of the ClientSize property changes.
Public eventContextMenuChanged
Occurs when the value of the ContextMenu property changes.
Public eventContextMenuStripChanged
Occurs when the value of the ContextMenuStrip property changes.
Public eventControlAdded (Inherited from Control.)
Public eventControlRemoved (Inherited from Control.)
Public eventCursorChanged
Occurs when the value of the Cursor property changes.
Public eventDisposed
Occurs when the component is disposed by a call to the Dispose method.
Public eventDockChanged
Occurs when the value of the Dock property changes.
Public eventDoubleClick
Occurs when the control is double-clicked.
Public eventDragDrop
Occurs when a drag-and-drop operation is completed.
Public eventDragEnter
Occurs when an object is dragged into the control's bounds.
Public eventDragLeave
Occurs when an object is dragged out of the control's bounds.
Public eventDragOver
Occurs when an object is dragged over the control's bounds.
Public eventEnabledChanged
Occurs when the Enabled property value has changed.
Public eventEnter
Occurs when the control is entered.
Public eventFontChanged
Occurs when the Font property value changes.
Public eventForeColorChanged
Occurs when the ForeColor property value changes.
Public eventGiveFeedback
Occurs during a drag operation.
Public eventGotFocus
Occurs when the control receives focus.
Public eventHandleCreated
Occurs when a handle is created for the control.
Public eventHandleDestroyed
Occurs when the control's handle is in the process of being destroyed.
Public eventHelpRequested
Occurs when the user requests help for a control.
Public eventImeModeChanged
Occurs when the ImeMode property has changed.
Public eventInvalidated
Occurs when a control's display requires redrawing.
Public eventKeyDown
Occurs when a key is pressed while the control has focus.
Public eventKeyPress
Public eventKeyUp
Occurs when a key is released while the control has focus.
Public eventLayout
Occurs when a control should reposition its child controls.
Public eventLeave
Occurs when the input focus leaves the control.
Public eventLoad
Occurs before the control becomes visible for the first time.
Public eventLocationChanged
Occurs when the Location property value has changed.
Public eventLostFocus
Occurs when the control loses focus.
Public eventMarginChanged
Occurs when the control's margin changes.
Public eventMouseCaptureChanged
Occurs when the control loses mouse capture.
Public eventMouseClick
Occurs when the control is clicked by the mouse.
Public eventMouseDoubleClick
Occurs when the control is double clicked by the mouse.
Public eventMouseDown
Occurs when the mouse pointer is over the control and a mouse button is pressed.
Public eventMouseEnter
Occurs when the mouse pointer enters the control.
Public eventMouseHover
Occurs when the mouse pointer rests on the control.
Public eventMouseLeave
Occurs when the mouse pointer leaves the control.
Public eventMouseMove
Occurs when the mouse pointer is moved over the control.
Public eventMouseUp
Occurs when the mouse pointer is over the control and a mouse button is released.
Public eventMouseWheel
Occurs when the mouse wheel moves while the control has focus.
Public eventMove
Occurs when the control is moved.
Public eventPaddingChanged
Occurs when the control's padding changes.
Public eventPaint
Occurs when the control is redrawn.
Public eventParentChanged
Occurs when the Parent property value changes.
Public eventPreviewKeyDown
Occurs before the KeyDown event when a key is pressed while focus is on this control.
Public eventQueryAccessibilityHelp
Occurs when AccessibleObject is providing help to accessibility applications.
Public eventQueryContinueDrag
Occurs during a drag-and-drop operation and enables the drag source to determine whether the drag-and-drop operation should be canceled.
Public eventRegionChanged
Occurs when the value of the Region property changes.
Public eventResize
Occurs when the control is resized.
Public eventRightToLeftChanged
Occurs when the RightToLeft property value changes.
Public eventScroll
Occurs when the user or code scrolls through the client area.
Public eventSizeChanged
Occurs when the Size property value changes.
Public eventStyleChanged
Occurs when the control style changes.
Public eventSystemColorsChanged
Occurs when the system colors change.
Public eventTabIndexChanged
Occurs when the TabIndex property value changes.
Public eventTabStopChanged
Occurs when the TabStop property value changes.
Public eventTextChanged (Inherited from UserControl.)
Public eventValidated
Occurs when the control is finished validating.
Public eventValidating
Occurs when the control is validating.
Public eventVisibleChanged
Occurs when the Visible property value changes.
Top
See Also
