TpsControlBeginInvoke Method (EventHandler, Object) |
Executes the specified delegate asynchronously with the specified arguments,
on the thread that the control's underlying handle was created on.
Namespace:
Assembly:
Syntaxpublic IAsyncResult BeginInvoke(
EventHandler method,
params Object[] args
Parameters
- method
- Type: SystemEventHandler
A delegate to a method that takes parameters of the same number and type
that are contained in the args parameter. - args
- Type: SystemObject
An array of objects to pass as arguments to the given method. This can be
null if no arguments are needed.
Return Value
Type:
IAsyncResultAn System.IAsyncResult that represents the result of the System.Windows.Forms.Control.BeginInvoke(System.Delegate)
operation.
Remarks This version only supports
EventHandler methods, so the args must fit these parameters; otherwise an exception will be thrown.
See Also
