Click or drag to resize
CommandBar Properties
The CommandBar type exposes the following members.
Properties
  NameDescription
Public propertyAccessibilityObject
Gets the AccessibleObject assigned to the control.
(Inherited from Control.)
Public propertyAccessibleDefaultActionDescription
Gets or sets the default action description of the control for use by accessibility client applications.
Public propertyAccessibleDescription
Gets or sets the description of the control used by accessibility client applications.
Public propertyAccessibleName
Gets or sets the name of the control used by accessibility client applications.
Public propertyAccessibleRole
Gets or sets the accessible role of the control
Public propertyActiveControl
Gets or sets the active control on the container control.
(Inherited from ContainerControl.)
Public propertyAllowDrop
Gets or sets a value indicating whether the control can accept data that the user drags onto it.
Public propertyAnchor
Gets or sets the edges of the container to which a control is bound and determines how a control is resized with its parent.
Public propertyAutoScaleDimensions
Gets or sets the dimensions that the control was designed to.
Protected propertyAutoScaleFactor
Gets the scaling factor between the current and design-time automatic scaling dimensions.
Public propertyAutoScaleMode
Gets or sets the automatic scaling mode of the control.
Public propertyAutoScroll
Gets or sets a value indicating whether the container enables the user to scroll to any controls placed outside of its visible boundaries.
(Inherited from ScrollableControl.)
Public propertyAutoScrollMargin
Gets or sets the size of the auto-scroll margin.
Public propertyAutoScrollMinSize
Gets or sets the minimum size of the auto-scroll.
Public propertyAutoScrollOffset
Gets or sets where this control is scrolled to in ScrollControlIntoView(Control).
Public propertyAutoScrollPosition
Gets or sets the location of the auto-scroll position.
Public propertyAutoSize (Inherited from UserControl.)
Public propertyAutoSizeMode
Gets or sets how the control will resize itself.
Public propertyAutoValidate
Gets or sets how the control performs validation when the user changes focus to another control.
Public propertyBackColor
Gets or sets the background color for the control.
Public propertyBackgroundImage
Gets or sets the background image displayed in the control.
Public propertyBackgroundImageLayout
Gets or sets the background image layout as defined in the ImageLayout enumeration.
Public propertyBindingContext (Inherited from ContainerControl.)
Public propertyBorderStyle
Gets or sets the border style of the user control.
Public propertyBottom
Gets the distance, in pixels, between the bottom edge of the control and the top edge of its container's client area.
Public propertyBounds
Gets or sets the size and location of the control including its nonclient elements, in pixels, relative to the parent control.
Protected propertyCanEnableIme
Gets a value indicating whether the ImeMode property can be set to an active value, to enable IME support.
Public propertyCanFocus
Gets a value indicating whether the control can receive focus.
Protected propertyCanRaiseEvents
Determines if events can be raised on the control.
Public propertyCanSelect
Gets a value indicating whether the control can be selected.
Public propertyCapture
Gets or sets a value indicating whether the control has captured the mouse.
Public propertyCausesValidation
Gets or sets a value indicating whether the control causes validation to be performed on any controls that require validation when it receives focus.
Public propertyClientRectangle
Gets the rectangle that represents the client area of the control.
Public propertyClientSize
Gets or sets the height and width of the client area of the control.
Public propertyCompanyName
Gets the name of the company or creator of the application containing the control.
Public propertyContainer
Gets the IContainer that contains the Component.
(Inherited from Component.)
Public propertyContainsFocus
Gets a value indicating whether the control, or one of its child controls, currently has the input focus.
Public propertyContextMenu
Gets or sets the shortcut menu associated with the control.
(Inherited from TpsControl.)
Public propertyContextMenuStrip
Gets or sets the ContextMenuStrip associated with this control.
Public propertyControls
Gets the collection of controls contained within the control.
Public propertyCreated
Gets a value indicating whether the control has been created.
Protected propertyCreateParams (Inherited from UserControl.)
Public propertyCurrentAutoScaleDimensions
Gets the current run-time dimensions of the screen.
Public propertyCursor
Gets or sets the cursor that is displayed when the mouse pointer is over the control.
Public propertyDataBindings
Gets the data bindings for the control.
Protected propertyDefaultCursor
Gets or sets the default cursor for the control.
Protected propertyDefaultImeMode
Gets the default Input Method Editor (IME) mode supported by the control.
Protected propertyDefaultMargin
Gets the space, in pixels, that is specified by default between controls.
Protected propertyDefaultMaximumSize
Gets the length and height, in pixels, that is specified as the default maximum size of a control.
Protected propertyDefaultMinimumSize
Gets the length and height, in pixels, that is specified as the default minimum size of a control.
Protected propertyDefaultPadding
Gets the internal spacing, in pixels, of the contents of a control.
Protected propertyDefaultSize (Inherited from UserControl.)
Protected propertyDesignMode
Gets a value that indicates whether the Component is currently in design mode.
Protected propertyDisabledForeColor
Gets or sets the value of the forecolor used when the control is disabled. Some controls do not change its visual appearance when disabled. This property has no effect for those controls.
Public propertyDisplayRectangle
Gets the rectangle that represents the virtual display area of the control.
Public propertyDisposing
Gets a value indicating whether the base Control class is in the process of disposing.
Public propertyDock
Gets or sets which control borders are docked to its parent control and determines how a control is resized with its parent.
Public propertyDockPadding
Gets the dock padding settings for all edges of the control.
Protected propertyDoubleBuffered
Gets or sets a value indicating whether this control should redraw its surface using a secondary buffer to reduce or prevent flicker.
Public propertyEnabled
Gets or sets a value indicating whether the control can respond to user interaction.
Protected propertyEvents
Gets the list of event handlers that are attached to this Component.
Public propertyFocused
Gets a value indicating whether the control has input focus.
Public propertyFont
Gets or sets the font of the text displayed by the control.
Protected propertyFontHeight
Gets or sets the height of the font of the control.
Public propertyFontName Obsolete.
The font that should be used for the TpsControl. The Control Font property is hidden from the property grid so that the user shouldn't be able to select Fonts which are not compatible with the FlexPendant.
Public propertyForeColor
Gets or sets the foreground color of the control.
Public propertyHandle
Gets the window handle that the control is bound to.
Public propertyHasChildren
Gets a value indicating whether the control contains one or more child controls.
Public propertyHeight
Gets or sets the height of the control.
Public propertyHorizontalScroll
Gets the characteristics associated with the horizontal scroll bar.
Protected propertyHScroll
Gets or sets a value indicating whether the horizontal scroll bar is visible.
Public propertyImeMode
Gets or sets the Input Method Editor (IME) mode of the control.
Protected propertyImeModeBase
Gets or sets the IME mode of a control.
Public propertyInvokeRequired
Gets a value indicating whether the caller must call an invoke method when making method calls to the control because the caller is on a different thread than the one the control was created on.
Public propertyIsAccessible
Gets or sets a value indicating whether the control is visible to accessibility applications.
Protected propertyCode exampleIsDisposed
Gets or sets a value indicating whether the object has already been disposed or not.
Public propertyIsEventEnabled
Gets or sets the status if events shall be processed by the control. This a property controlled by the derived class but the default behaviour is true in the constructor and false in the Dispose method.
Public propertyIsHandleCreated
Gets a value indicating whether the control has a handle associated with it.
Public propertyIsMirrored
Gets a value indicating whether the control is mirrored.
Public propertyLayoutEngine
Gets a cached instance of the control's layout engine.
Public propertyLeft
Gets or sets the distance, in pixels, between the left edge of the control and the left edge of its container's client area.
Public propertyLocation
Gets or sets the coordinates of the upper-left corner of the control relative to the upper-left corner of its container.
Public propertyMargin
Gets or sets the space between controls.
Public propertyMaximumSize
Gets or sets the size that is the upper limit that GetPreferredSize(Size) can specify.
Public propertyMenu
Gets or sets the MainMenu that is host by the CommandBar.
Public propertyMenuItems
Gets the menu itmes in commandbar
Public propertyMinimumSize
Gets or sets the size that is the lower limit that GetPreferredSize(Size) can specify.
Public propertyName
Gets or sets the name of the control.
Public propertyPadding
Gets or sets padding within the control.
Public propertyParent
Gets or sets the parent container of the control.
Public propertyParentForm
Gets the form that the container control is assigned to.
Public propertyPreferredSize
Gets the size of a rectangular area into which the control can fit.
Public propertyProductName
Gets the product name of the assembly containing the control.
Public propertyProductVersion
Gets the version of the assembly containing the control.
Public propertyRecreatingHandle
Gets a value indicating whether the control is currently re-creating its handle.
Public propertyRegion
Gets or sets the window region associated with the control.
Protected propertyRenderRightToLeft Obsolete.
This property is now obsolete.
Protected propertyResizeRedraw
Gets or sets a value indicating whether the control redraws itself when resized.
Public propertyRight
Gets the distance, in pixels, between the right edge of the control and the left edge of its container's client area.
Public propertyRightToLeft
Gets or sets a value indicating whether control's elements are aligned to support locales using right-to-left fonts.
Protected propertyScaleChildren
Gets a value that determines the scaling of child controls.
Public propertySelectionColor
Gets or sets the color when an item is selected. Default color is RGB(0,172,182)
Protected propertyShowFocusCues
Gets a value indicating whether the control should display focus rectangles.
Protected propertyShowKeyboardCues
Gets a value indicating whether the user interface is in the appropriate state to show or hide keyboard accelerators.
Public propertySite
Gets or sets the site of the control.
Public propertySize
Gets or sets the height and width of the control.
Public propertyTabIndex
Gets or sets the tab order of the control within its container.
Public propertyTabStop
Gets or sets a value indicating whether the user can give the focus to this control using the TAB key.
Public propertyTag
Gets or sets the object that contains data about the control.
Public propertyText (Inherited from UserControl.)
Public propertyTop
Gets or sets the distance, in pixels, between the top edge of the control and the top edge of its container's client area.
Public propertyTopLevelControl
Gets the parent control that is not parented by another Windows Forms control. Typically, this is the outermost Form that the control is contained in.
Public propertyUseWaitCursor
Gets or sets a value indicating whether to use the wait cursor for the current control and all child controls.
Public propertyVerticalScroll
Gets the characteristics associated with the vertical scroll bar.
Public propertyVisible
Gets or sets a value indicating whether the control and all its child controls are displayed.
Protected propertyVScroll
Gets or sets a value indicating whether the vertical scroll bar is visible.
Public propertyWidth
Gets or sets the width of the control.
Public propertyWindowTarget
This property is not relevant for this class.
Top
See Also
