TpsControlFontName Property |
Note: This API is now obsolete.
the FlexPendant.
Namespace:
Assembly:
Syntax[ObsoleteAttribute("Use the property Font instead", false)]
public virtual DesignerFont FontName { get; set; }Property Value
Type:
DesignerFont
See Also
