DesignerFont Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class DesignerFont
The DesignerFont type exposes the following members.
| Name | Description | |
| DesignerFont |
Constructor for the DesignerFont.
| Bold |
Returns if the style of the font is bold or not.
| Font |
The System.Drawing.Font associated with this DesignerFont. Retrieves a static
Font from the TpsFont-class using the selected font name.
| FontName |
The name of the font. The name should match one of the publicly available static Fonts in
TpsFont. This property is used by the ABB.Robotics.Tps.ABBControlDesigner.FontConverter in
order to generate code for the DesignerFont-object in in design-time.
| Size |
Returns the size of the font.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetFontNames |
This method is called by the TpsFontEditorForm to show a list of all available FP compatible fonts.
| ToString |
Returns the name of the currently selected font,
which is shown in the property grid in the designer.
(Overrides ObjectToString.) |
