TpsControlBeginInvokeEx Method |
Note: This API is now obsolete.
Executes the specified EventHandler asynchronously.
Namespace:
Assembly:
Syntax[ObsoleteAttribute("This method is obsolete and will be removed in the next version. Use BeginInvoke instead.")]
public void BeginInvokeEx(
EventHandler eh,
params Object[] args
)Parameters
- eh
- Type: SystemEventHandler
EventHandler to be executed. - args
- Type: SystemObject
An array of objects to pass as arguments to the given method. This can be null if no arguments are needed.
See Also
