Click or drag to resize
ListViewItemListViewSubItem Class
Note: This API is now obsolete.
This class if for backwards compatibility only. Use the class ABB.Robotics.Tps.Windows.Forms.ListViewSubItem instead.
Inheritance Hierarchy
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
[ObsoleteAttribute("This class is obsolete. Use ABB.Robotics.Tps.Windows.Forms.ListViewSubItem instead.")]
public class ListViewSubItem : ListViewSubItem
The ListViewItemListViewSubItem type exposes the following members.
Constructors
  NameDescription
Public methodListViewItemListViewSubItem
Initializes a new instance of the ListViewItemListViewSubItem class.
Top
Properties
  NameDescription
Protected propertyCanRaiseEvents
Gets a value indicating whether the component can raise an event.
(Inherited from Component.)
Public propertyContainer
Gets the IContainer that contains the Component.
Protected propertyDesignMode
Gets a value that indicates whether the Component is currently in design mode.
Protected propertyEvents
Gets the list of event handlers that are attached to this Component.
Public propertyForeColor
Gets or sets the foreground color of the subitem's text.
(Inherited from ListViewSubItem.)
Public propertyImageIndex
Gets or sets the index of the image that is displayed for the item.
Public propertyImageList
Gets the ImageList that contains the image displayed with the item.
Public propertySite
Gets or sets the ISite of the Component.
Public propertyText
Gets or sets the text of the subitem.
Top
Methods
  NameDescription
Public methodCreateObjRef
Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object.
(Inherited from MarshalByRefObject.)
Public methodDispose
Releases all resources used by the Component.
Protected methodDispose(Boolean)
Releases the unmanaged resources used by the Component and optionally releases the managed resources.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Releases unmanaged resources and performs other cleanup operations before the Component is reclaimed by garbage collection.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetLifetimeService
Retrieves the current lifetime service object that controls the lifetime policy for this instance.
Protected methodGetService
Returns an object that represents a service provided by the Component or by its Container.
Public methodGetType
Gets the type of the current instance.
Public methodInitializeLifetimeService
Obtains a lifetime service object to control the lifetime policy for this instance.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodMemberwiseClone(Boolean)
Creates a shallow copy of the current MarshalByRefObject object.
Public methodToString
Returns a String containing the name of the Component, if any. This method should not be overridden.
Top
Events
  NameDescription
Public eventDisposed
Occurs when the component is disposed by a call to the Dispose method.
Top
See Also
