Click or drag to resize
ListViewColumnHeaderCollection Class
Represents the collection of column headers in a ListView control.
Inheritance Hierarchy
SystemObject
  System.CollectionsCollectionBase
    ABB.Robotics.Tps.Windows.FormsListViewColumnHeaderCollection
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public class ColumnHeaderCollection : CollectionBase
The ListViewColumnHeaderCollection type exposes the following members.
Properties
  NameDescription
Public propertyCapacity
Gets or sets the number of elements that the CollectionBase can contain.
(Inherited from CollectionBase.)
Public propertyCount
Gets the number of elements contained in the CollectionBase instance. This property cannot be overridden.
Protected propertyInnerList
Gets an ArrayList containing the list of elements in the CollectionBase instance.
Public propertyItem
Retrieves the ColumnHeader at the specified indexed location in the collection.
Protected propertyList
Gets an IList containing the list of elements in the CollectionBase instance.
Top
Methods
  NameDescription
Public methodAdd(ColumnHeader)
Adds an existing ColumnHeader object to the collection.
Public methodAdd(String, Int32, HorizontalAlignment)
Adds a column header to the collection with specified text, width, and alignment settings.
Public methodClear
Removes all objects from the CollectionBase instance. This method cannot be overridden.
Public methodContains
Determines if the specified ColumnHeader is a member of the collection.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection.
Public methodGetEnumerator
Returns an enumerator that iterates through the CollectionBase instance.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetType
Gets the type of the current instance.
Public methodIndexOf
Returns the index within the collection of the specified item.
Public methodInsert
Inserts an existing ColumnHeader into the collection at the specified index.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodOnClear
Overridden. Stores a copy of the ColumnHeader objects to remove their connections.
(Overrides CollectionBaseOnClear.)
Protected methodOnClearComplete
Overridden. Removes the connection of the ColumnHeader stored.
(Overrides CollectionBaseOnClearComplete.)
Protected methodOnInsert
Performs additional custom processes before inserting a new element into the CollectionBase instance.
Protected methodOnInsertComplete
Overridden. Adds the connection of the ColumnHeader.
(Overrides CollectionBaseOnInsertComplete(Int32, Object).)
Protected methodOnRemove
Performs additional custom processes when removing an element from the CollectionBase instance.
Protected methodOnRemoveComplete
Overridden. Removes the connection of the ColumnHeader.
(Overrides CollectionBaseOnRemoveComplete(Int32, Object).)
Protected methodOnSet
Performs additional custom processes before setting a value in the CollectionBase instance.
Protected methodOnSetComplete
Performs additional custom processes after setting a value in the CollectionBase instance.
Protected methodOnValidate
Performs additional custom processes when validating a value.
Public methodRemove
Removes the specified ColumnHeader from the collection.
Public methodRemoveAt
Removes the element at the specified index of the CollectionBase instance. This method is not overridable.
Public methodToString
Returns a string that represents the current object.
Top
Remarks
This class belongs to the pre-defined UI controls of the Tps SDK.
See Also
