FlexPendant Developer Support
FlexPendant Development
References
ListView.ColumnHeaderCollection Class
ColumnHeaderCollection Methods
Add Method
Contains Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
ListView
Contains Method
Determines if the specified
ColumnHeader
is a member of the collection.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
bool
Contains
ColumnHeader
item
Parameters
item
Type:
ColumnHeader
The
ColumnHeader
to locate in the collection.
Return Value
Type:
Boolean
true
if the
ColumnHeader
is a member of the collection; otherwise,
false
See Also
Reference
ListView
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
