FlexPendant Developer Support
FlexPendant Development
References
ListView.ColumnHeaderCollection Class
ColumnHeaderCollection Methods
Add Method
Contains Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
ListView
Insert Method
Inserts an existing
ColumnHeader
into the collection at the specified index.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
ColumnHeader
Insert
int
index
ColumnHeader
item
Parameters
index
Type:
System
Int32
The zero-based index location where the item is inserted.
item
Type:
ColumnHeader
The
ColumnHeader
that represents the item to insert.
Return Value
Type:
ColumnHeader
The
ColumnHeader
that was inserted into the collection.
See Also
Reference
ListView
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
