ColumnHeader Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class ColumnHeader : Component, ICloneable
The ColumnHeader type exposes the following members.
| Name | Description | |
| ColumnHeader |
Initializes a new instance of the ColumnHeader class.
| ColumnHeader(String) |
| CanRaiseEvents | Gets a value indicating whether the component can raise an event. (Inherited from Component.) | |
| DesignMode | Gets a value that indicates whether the Component is currently in design mode. (Inherited from Component.) | |
| Events | Gets the list of event handlers that are attached to this Component. (Inherited from Component.) | |
| HeaderSorter | Gets or sets the sorting comparer for the column when the column header is clicked. | |
| Site | (Inherited from Component.) | |
| Text | Gets or sets the text displayed in the column . | |
| TextAlign | Gets or sets the horizontal alignment of the text displayed in the ColumnHeader. | |
| Width | Gets or sets the width of the column. |
| Clone |
Creates an identical copy of the current ColumnHeader that is not attached to any list view control.
| CreateObjRef | Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object. (Inherited from MarshalByRefObject.) | |
| Dispose | Releases all resources used by the Component. (Inherited from Component.) | |
| Dispose(Boolean) | Releases the unmanaged resources used by the Component and optionally releases the managed resources. (Inherited from Component.) | |
| Finalize | Releases unmanaged resources and performs other cleanup operations before the Component is reclaimed by garbage collection. (Inherited from Component.) | |
| GetLifetimeService | Retrieves the current lifetime service object that controls the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| GetService | (Inherited from Component.) | |
| InitializeLifetimeService | Obtains a lifetime service object to control the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| MemberwiseClone(Boolean) | Creates a shallow copy of the current MarshalByRefObject object. (Inherited from MarshalByRefObject.) | |
| ToString | Returns a String containing the name of the Component, if any. This method should not be overridden. (Inherited from Component.) |
| Disposed | Occurs when the component is disposed by a call to the Dispose method. (Inherited from Component.) |
