StateObject Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class StateObject : Dictionary<string, Object>
The StateObject type exposes the following members.
| Name | Description | |
| StateObject |
Initializes a new StateObject
| StateObject(Object) |
Initializes a new StateObject with a specific value
| Comparer | Gets the IEqualityComparerT that is used to determine equality of keys for the dictionary. (Inherited from DictionaryString, Object.) | |
| Count | Gets the number of key/value pairs contained in the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| Item | Gets or sets the value associated with the specified key. (Inherited from DictionaryString, Object.) | |
| Keys | Gets a collection containing the keys in the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| Value |
Gets or sets the value to which this state will respond
| Values | Gets a collection containing the values in the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) |
| Add | Adds the specified key and value to the dictionary. (Inherited from DictionaryString, Object.) | |
| Clear | Removes all keys and values from the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| ContainsKey | Determines whether the DictionaryTKey, TValue contains the specified key. (Inherited from DictionaryString, Object.) | |
| ContainsValue | Determines whether the DictionaryTKey, TValue contains a specific value. (Inherited from DictionaryString, Object.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetEnumerator | Returns an enumerator that iterates through the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| GetObjectData | Implements the ISerializable interface and returns the data needed to serialize the DictionaryTKey, TValue instance. (Inherited from DictionaryString, Object.) | |
| OnDeserialization | Implements the ISerializable interface and raises the deserialization event when the deserialization is complete. (Inherited from DictionaryString, Object.) | |
| Remove | Removes the value with the specified key from the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| ToString |
Overridden.
(Overrides ObjectToString.) | |
| TryGetValue | Gets the value associated with the specified key. (Inherited from DictionaryString, Object.) |
