StateObject Methods |
The StateObject type exposes the following members.
| Name | Description | |
| Add | Adds the specified key and value to the dictionary. (Inherited from DictionaryString, Object.) | |
| Clear | Removes all keys and values from the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| ContainsKey | Determines whether the DictionaryTKey, TValue contains the specified key. (Inherited from DictionaryString, Object.) | |
| ContainsValue | Determines whether the DictionaryTKey, TValue contains a specific value. (Inherited from DictionaryString, Object.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetEnumerator | Returns an enumerator that iterates through the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| GetObjectData | Implements the ISerializable interface and returns the data needed to serialize the DictionaryTKey, TValue instance. (Inherited from DictionaryString, Object.) | |
| OnDeserialization | Implements the ISerializable interface and raises the deserialization event when the deserialization is complete. (Inherited from DictionaryString, Object.) | |
| Remove | Removes the value with the specified key from the DictionaryTKey, TValue. (Inherited from DictionaryString, Object.) | |
| ToString |
Overridden.
(Overrides ObjectToString.) | |
| TryGetValue | Gets the value associated with the specified key. (Inherited from DictionaryString, Object.) |
