GTPUMessageBox Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class GTPUMessageBox
The GTPUMessageBox type exposes the following members.
| Name | Description | |
| GTPUMessageBox | Initializes a new instance of the GTPUMessageBox class |
| CloseMessageBox |
Sets a dialog result and closes the MessageBox.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| Show(Control, MessageBoxEventHandler, String, Object) |
Displays a MessageBox inside an specific UI with an specified text.
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, icon and buttons.
| Show(Control, MessageBoxEventHandler, String, String, Image, MessageBoxButtons, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, image and buttons.
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, String, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Control, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, String, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Control, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Control, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Boolean, String, Object) | ||
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Control, Boolean, Object) |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
class Foo : Control { public void Test () { GTPUMessageBox.Show(this, new MessageBoxEventHandler(this.MessageBox_Closing), "message"); } private void MessageBox_Closing(object sender, MessageBoxEventArgs me) { ... // The dialog result and the text associated with the pressed button are available through the second parameter. ... } }
