GTPUMessageBoxShow Method (Control, MessageBoxEventHandler, String, String, Image, MessageBoxButtons, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, image and buttons.
Namespace:
Assembly:
ABB.Robotics.GTPU.Windows.Forms (in ABB.Robotics.GTPU.Windows.Forms.dll) Version: 6.5.129.0
Syntaxpublic static void Show(
Control owner,
MessageBoxEventHandler callback,
string text,
string caption,
Image imageIcon,
MessageBoxButtons buttons,
params Object[] state
Parameters
- owner
- Type: System.Windows.FormsControl
The UI where the MessageBox will be showned. - callback
- Type: ABB.Robotics.Tps.Windows.FormsMessageBoxEventHandler
Handler to notity when the MessageBox has closed - text
- Type: SystemString
The text to display in the MessageBox. - caption
The text to display in the title bar of the MessageBox. - imageIcon
- Type: System.DrawingImage
The image to displaye in the MessageBox. The maximum size of this image is 50 x 50. - buttons
- Type: System.Windows.FormsMessageBoxButtons
One of the MessageBoxButtons values that specifies which buttons to display in MessageBox. - state
- Type: SystemObject
Optional argument. An object containing data to be used by the callback. This state could be retrieved using State.
NOTE: Neither state accepts more tna one optional arguments, onl the first one will be used.
See Also
