GTPUMessageBoxShow Method (Control, MessageBoxEventHandler, String, String, Image, String, Control, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, icon and buttons.
Namespace:
Assembly:
ABB.Robotics.GTPU.Windows.Forms (in ABB.Robotics.GTPU.Windows.Forms.dll) Version: 6.5.129.0
Syntaxpublic static void Show(
Control owner,
MessageBoxEventHandler callback,
string text,
string caption,
Image imageIcon,
string[] strButtons,
out Control ctrl,
params Object[] state
Parameters
- owner
- Type: System.Windows.FormsControl
The UI where the MessageBox will be showned. - callback
- Type: ABB.Robotics.Tps.Windows.FormsMessageBoxEventHandler
Handler to notity when the MessageBox has closed - text
- Type: SystemString
The text to display in the MessageBox. - caption
The text to display in the title bar of the MessageBox. - imageIcon
- Type: System.DrawingImage
The image to displaye in the MessageBox. The maximum size of this image is 50 x 50. - strButtons
An array of string that represent the buttons that will be showned as options. - ctrl
The reference the UI of the Message Box. This reference must not be disposed by the client. - state
- Type: SystemObject
Optional argument. An object containing data to be used by the callback. This state could be retrieved using State.
NOTE: Neither state accepts more than one optional arguments, only the first one will be used.
See Also
