GTPUMessageBox Methods |
The GTPUMessageBox type exposes the following members.
| Name | Description | |
| CloseMessageBox |
Sets a dialog result and closes the MessageBox.
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| Show(Control, MessageBoxEventHandler, String, Object) |
Displays a MessageBox inside an specific UI with an specified text.
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, icon and buttons.
| Show(Control, MessageBoxEventHandler, String, String, Image, MessageBoxButtons, Object) |
Displays a MessageBox inside an specific UI with an specified text, caption, image and buttons.
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, String, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Control, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, String, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Control, Object) |
| Show(Control, MessageBoxEventHandler, String, String, Image, String, Control, Boolean, Object) |
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Boolean, String, Object) | ||
| Show(Control, MessageBoxEventHandler, String, String, MessageBoxIcon, MessageBoxButtons, Control, Boolean, Object) |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
