ContextMenu Class |
Namespace: ABB.Robotics.Tps.Windows.Forms
public class ContextMenu : Menu
The ContextMenu type exposes the following members.
| Name | Description | |
| ContextMenu |
Initializes a new instance of the ContextMenu class.
| CanRaiseEvents | Gets a value indicating whether the component can raise an event. (Inherited from Component.) | |
| DesignMode | Gets a value that indicates whether the Component is currently in design mode. (Inherited from Component.) | |
| Events | Gets the list of event handlers that are attached to this Component. (Inherited from Component.) | |
| IsParent | Gets a value indicating whether this menu contains any menu items. (Inherited from Menu.) | |
| MenuItems | Gets a value indicating the collection of MenuItem objects associated with the menu. (Inherited from Menu.) | |
| Site | (Inherited from Component.) |
| CreateObjRef | Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object. (Inherited from MarshalByRefObject.) | |
| Dispose | Releases all resources used by the Component. (Inherited from Component.) | |
| Dispose(Boolean) | Releases the unmanaged resources used by the Component and optionally releases the managed resources. (Inherited from Component.) | |
| Finalize | Releases unmanaged resources and performs other cleanup operations before the Component is reclaimed by garbage collection. (Inherited from Component.) | |
| GetLifetimeService | Retrieves the current lifetime service object that controls the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| GetService | (Inherited from Component.) | |
| InitializeLifetimeService | Obtains a lifetime service object to control the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| MemberwiseClone(Boolean) | Creates a shallow copy of the current MarshalByRefObject object. (Inherited from MarshalByRefObject.) | |
| OnPopUp |
Overriden. Raises the PopUp event.
| Show |
This method will create the specified context menu.
| ToString | Returns a String containing the name of the Component, if any. This method should not be overridden. (Inherited from Component.) |
| Disposed | Occurs when the component is disposed by a call to the Dispose method. (Inherited from Component.) | |
| PopUp |
Occurs before the shortcut menu is displayed.
