Rapid Methods |
The Rapid type exposes the following members.
| Name | Description | |
| Dispose |
Dispose the managed resources of the instance.
(Overrides SDKDisposeBaseDispose.) | |
| GetRapidData | Gets a RapidData object that references a RAPID data instance in the robot controller. | |
| GetRapidDataType |
Gets the type definition for a RAPID data.
| GetTask |
Gets a Task object referencing a specific task.
| GetTasks | Gets the tasks defined in the RAPID domain. | |
| ResetProgramPointer |
Resets the program pointer of all active tasks to their respective main routine
| Start |
Starts RAPID program execution in continuous mode, with Regain Mode Clear and with the
current execution cycle as set in the robot controller.
| Start(RegainMode, ExecutionMode) |
Starts RAPID program execution with the settings as in the call and with the
| Start(RegainMode, ExecutionMode, ExecutionCycle) | Obsolete.
Starts RAPID program execution with the settings as in the call.
| Stop |
Stops RAPID program execution - an immediate stop is performed.
| Stop(StopMode) |
Stops RAPID program execution according to the specified mode
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
