GrantCalibrateRobot Field |
Gives access to perform the following: Fine calibrate mechanical unit,
Calibrate base frame, Update/clear SMB data. Note! Frame calibration (tool, wobj)
requires the grant RAPID code. Manual offset of mechanical unit calibration
data and loading new calibration data from file require grant Modify configuration.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic static Grant CalibrateRobot
Field Value
Type:
Grant
See Also
