GrantAdministrateSystem Field |
Gives access to perform the following: Install new system, P-start, I-start, X-start,
C-start, Select System, Install system from device. This grant gives full FTP access,
that is, the grant gives the same rights as Read access to controller disks and Write
access to controller disks.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic static Grant AdministrateSystem
Field Value
Type:
Grant
See Also
