GrantWriteConfiguration Field |
Gives access to modify the configuration database, that is load configuration files,
change system parameter values and add/delete instances.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic static Grant WriteConfiguration
Field Value
Type:
Grant
See Also
