Gives access to perform the following: Set I/O signal value, Set signal as simulated
and remove simulation, Set I/O unit and bus as enabled/disabled
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxpublic static Grant WriteIO
Field Value
Type:
Grant
See Also
