Signal Binding |
The Signal Binding application is a sample application which shows how to bind signals with controls such as Data Grid.
If you encounter some build errors when this sample application is built, you need to add the DLL references. Refer How to build and execute in How to build and execute on FlexPendant tutorial. |
This sample application uses these controls – Group Box, Data Grid, Buttons and Labels.
As the above user interface image shows, we are binding a set of signals to a data grid control. The 1 and 0 buttons on the right are used to modify the value of a selected signal.
Managing signals can be done from the IOSignals.cfg file. All modifications done in this file are reflected on the data grid and also vice versa.
Memory management:
Stability:
Data binding:
Others:
