ABB.Robotics.Diagnostics Namespace |
| Class | Description | |
| Debug |
Provides a set of methods and properties that help debug your code.
| FlexPendant |
It' a class defined FlexPendant information
| Trace |
Provides a set of methods and properties that help you trace the execution of your code.
| Structure | Description | |
| CapacityInfo |
This struct defines the memory information for FlexPendant and the unit for the number is kilo byte
| MEMORYSTATUSEX |
struct to retrive memory status
