Debug Class |
Namespace: ABB.Robotics.Diagnostics
public abstract class Debug
The Debug type exposes the following members.
| Name | Description | |
| Assert(Boolean) |
Checks for a condition and displays an assert message on the FlexPendant, containing a stack trace,
if the condition is false.
When the condition is false, the assert message, with a stack trace, is also sent out on the network.
The message can be displayed in the controller console by enabling the functionality on the controller.
Use fpcmd_enable_console_output to enable FlexPendant logging.
| Assert(Boolean, String) |
When the condition is false, the message, with a stack trace, is also sent out on the network.
| Assert(Boolean, String, String) |
Checks for a condition and displays an assert message on the FlexPendant, with detailed
information and a stack trace, if the condition is false.
When the condition is false, the message, with detailed information and a stack trace,
is also sent out on the network. The message can be displayed in the controller
console by enabling the functionality on the controller. Use fpcmd_enable_console_output
| Fail(String) |
An error message, with a stack trace, is displayed on the FlexPendant.
The error message, with a stack trace, is also sent out on the network. The
error message can be displayed in the controller console by enabling the functionality
on the controller. Use fpcmd_enable_console_output to enable FlexPendant logging.
| Fail(String, String) |
An error message, with detailed error information and a stack trace, is displayed on the FlexPendant.
The error message, with detailed error information and a stack trace, is also sent out on the network.
The error message can be displayed in the controller console by enabling the functionality
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) | |
| Write |
A debug message is sent out on the network. The message can be displayed in the controller console
by enabling the functionality on the controller. Use fpcmd_enable_console_output to enable
| WriteIf |
Checks for a condition and sends a debug message out on the network if the condition is true.
| WriteLine |
| WriteLineIf |
Debug.Fail("Operation not allowed in current state", string.Format("state: {0}", myobj.State.ToString()));
